Pro Panel help
Тools, Elcad, Eplan, ...
luuxiii
Pro Panel help
Post by luuxiii »
I place a components from 3D Mounting layout (eg. A999)
after I place components, the new A999 shows up with red dot infront.
Why does this happend ?
lin2m3
Re: Pro Panel help
Post by lin2m3 »
Be sure you have unique DT on every part and Ful DT field filled. If your part has more sub-parts, either you unite them or define them with a unique DT(Full DT). Red dot shows you have an error in the project from the view point of Propanel.
luuxiii
Re: Pro Panel help
Post by luuxiii »
lin2m3 wrote:Be sure you have unique DT on every part and Ful DT field filled. If your part has more sub-parts, either you unite them or define them with a unique DT(Full DT). Red dot shows you have an error in the project from the view point of Propanel.
Thank you very much. I'll take a look in this matter :)
