[?]: Can't connect to Siemens s1200 and ktp400 with wi-fi
AlekMalek
Post by AlekMalek »
Hi all. I'm new in Siemens automation.
It's currently my first project on it.
We bought KTP400 (HMI) and s1200 (PLC).
I physically connected them to router.
My PC uses wi-fi.
I can't connect to down load programs on them.
They are completely new.
When I chose in "online" search, I get error
" Failed to establish connection to the device with adress xxx.xxx"
IP address of HMI is known and ping is very good with it.
I think I do something wrong because I also can't connect to PLC.
What I should do?
I use TIA v14, my OS PC is win7 x64.
Re: [?]: Can't connect to Siemens s1200 and ktp400 with wi-f
in my WiFi all work - s7-1200/1500, TP700
AlekMalek
Post by AlekMalek »
CoMod wrote:in my WiFi all work - s7-1200/1500, TP700
I have this devices in the network now but
https://drive.google.com/file/d/0B2rjeb ... sp=sharing
And I also see ping from HMI. It's very suspiciously that I don't see any Siemens device in the network. May be something wrong with my soft or windows. I have win7 rus slightly old.
"I have this devices in the network now ..."
In this case, the problem is in the settings transfer in panel.
Устройства из коробки с нулёвыми адресами 0.0.0.0 ?
попробуй
try SIMATIC Automation Tool - the commissioning and service operation tool for SIMATIC modules
https://support.industry.siemens.com/cs ... ic-modules
AlekMalek
Post by AlekMalek »
Simatic automation tool gives the same results.
I've get good connection to plc and hmi with direct Ethernet conection cable. But I can't in such thing connect two devices simultaneously. It seems that devices don't see router.
Dfcz wrote:...the problem is in the settings transfer in panel.
AlekMalek
Post by AlekMalek »
I didn't found where I nead to turn on Wi-Fi router except device-configuration, There is "use router" but it doesn't helps me. I've ignored this error by connecting devices directly and using simple switch. Of course web-server will not work.
