Analog scaling in Step 7
internal
Post by internal »
I have CPU 312-2DP and digital and analog i/o modules , I want to make a program which work like this
there is a input signal to the Analog module with range of 0-10 vdc , i want to save this values in a data block , please let me know what memory type i should use word or int or real , i use word or double word
once the value is saved in the data block i want to use this data block address and not scale this value to 0-5 v range and move output to the Analog output module
jokfem2016
Re: Analog scaling in Step 7
Post by jokfem2016 »
internal wrote:I have CPU 312-2DP and digital and analog i/o modules , I want to make a program which work like this
Select FC 105 from standard library... Define your high and low setpoint. For this block your high and low limit will be real (data type) meaning you are going to use double word.. Your analog output is going to be real as well.. After this select FC 106 to unscale your output value to an integer data type for your analog output card.. Hope this is helpful..
L PIW 256 // ANALOGICA TRASDUTTORE
L 0
<=I
JC PR
L 69
/I
PR: T #PRESSURE // PRESSIONE
T MW250 // PRESSIONE
T MD260 // PRESSIONE
T DB1.DBW 0 // PRESSIONE
This is input validation.
L PIW 256 // LETTURA TRASDUTTORE
L W#16#7FFF // ERRORE
==I
O(
L W#16#8000 // ERRORE
==I
= M 126.1 // ALLARME
