WHAT DOING THIS BLOCK ?
milhaushk
Post by milhaushk »
Hi help my please what doing this block ?
https://ulozto.cz/!OvdiwNBm3vgs/fc1-awl
(close)
Spoiler
FUNCTION FC 1 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
  IN0 : BOOL ;
  IN1 : INT ;
  IN2 : BOOL ;
  IN3 : BOOL ;
END_VAR
VAR_OUTPUT
  OUT4 : BOOL ;
END_VAR
VAR_IN_OUT
  IO5 : DINT ;
END_VAR
VAR_TEMP
  TEMP6 : STRUCT
   TEMP7 : BOOL ;
   TEMP8 : BOOL ;
   TEMP9 : BOOL ;
   TEMP10 : BOOL ;
   TEMP11 : BOOL ;
   TEMP12 : BOOL ;
   TEMP13 : BOOL ;
   TEMP14 : BOOL ;
   TEMP15 : BYTE ;
   TEMP16 : BYTE ;
   True_if_IN2 : BOOL ;	//Pokud je IO2 1 tak je hodnota 1
   True_if_IN3 : BOOL ;	//Pokud je IO3 1 tak je hodnota 1
   TEMP19 : BOOL ;
   TEMP20 : BOOL ;
   TEMP21 : BOOL ;
   TEMP22 : BOOL ;
   TEMP23 : BOOL ;
   TEMP24 : BOOL ;
  END_STRUCT ;
  IO1kr1 : BYTE ;	//IO1 nбsobek jednй IO1 * 1
  TEMP26 : BOOL ;
  TEMP27 : BOOL ;
  Math_2 : BYTE ;	//Nбsobek matematickэ 1*2 ????
  IO1bez2 : BYTE ;	//VstupIO1 menљн o 2
  TEMP30 : BOOL ;
END_VAR
BEGIN
NETWORK
TITLE =
      L     1;
      L     2;
      *I    ;
      T     #Math_2; // nasobek 1*2
      L     #IN1;
      L     1;
      *I    ; // nasobek vstup int1 * 1
      L     #Math_2;
      -I    ; // odecti
      T     #IO1bez2; // IN1 menљн o 2
      L     #IN1; // mensi temp28 o dva
      L     1;
      *I    ;
      T     #IO1kr1; // IO1 VYNБSOBENЭ 1
      L     #IO5;
      T     LD     0;
NETWORK
TITLE =
      AN    #IN0; // pokud nenн InO
      JCN   M004; // pokud nenн RLO 0 Skok nakonec Netvorku
      A     #IN2; // Pokud je INO 2
      =     #TEMP6.True_if_IN2; // Nastav Temp6.Temp14 na 1
      A     #IN3; // Pokud je IN3
      =     #TEMP6.True_if_IN3; // Nastav Temp6.Temp18 na 1
M004: NOP   1;
NETWORK
TITLE =
      A     #TEMP6.TEMP7;
      X     #TEMP6.TEMP19;
      =     #TEMP26;
      R     #TEMP6.TEMP20;
      A     #TEMP6.TEMP7;
      =     #TEMP6.TEMP19;
      A     #IN0;
      JCN   M001;
      A     #TEMP6.TEMP7;
      A(    ;
      L     #TEMP6.TEMP16;
      L     #Math_2;
      >I    ;
      R     #TEMP6.True_if_IN2;
      AN    #TEMP6.TEMP7;
      A(    ;
      L     #TEMP6.TEMP16;
      L     #IO1kr1;
      >=I   ;
      S     #TEMP6.True_if_IN2;
      AN    #TEMP6.TEMP7;
      A(    ;
      L     #TEMP6.TEMP16;
      L     #Math_2;
      >I    ;
      R     #TEMP6.True_if_IN3;
      A     #TEMP6.TEMP7;
      A(    ;
      L     #TEMP6.TEMP16;
      L     #IO1kr1;
      >=I   ;
      S     #TEMP6.True_if_IN3;
M001: NOP   1;
      AN    #TEMP6.TEMP7;
      A     #TEMP6.True_if_IN2;
      AN    #TEMP6.True_if_IN3;
      O(    ;
      A     #TEMP6.TEMP7;
      AN    #TEMP6.True_if_IN2;
      A     #TEMP6.True_if_IN3;
      =     #TEMP30;
      A     #TEMP30;
      S     #TEMP6.TEMP20;
      AN    #TEMP30;
      O     #TEMP6.TEMP14;
      JCN   M002;
      L     #TEMP6.TEMP16;
      L     127;
      <I    ;
      A     M      1.5;
      JCN   M002;
      L     #TEMP6.TEMP16;
      +     1;
      T     #TEMP6.TEMP16;
M002: NOP   1;
      A(    ;
      A     #TEMP26;
      O     #TEMP6.TEMP20;
      AN    #TEMP6.TEMP14;
      JCN   M003;
      L     0;
      T     #TEMP6.TEMP16;
M003: NOP   1;
NETWORK
TITLE =
      A(    ;
      L     #TEMP6.TEMP16;
      L     #IO1kr1;
      >I    ;
      AN    #TEMP6.TEMP14;
      O(    ;
      AN    #TEMP30;
      A     #TEMP6.TEMP20;
      JCN   M006;
      SET   ;
      R     #TEMP6.TEMP20;
      S     #TEMP6.TEMP14;
      L     0;
      T     #TEMP6.TEMP16;
M006: NOP   1;
      A     #TEMP30;
      A(    ;
      L     #TEMP6.TEMP16;
      L     2;
      >=I   ;
      JCN   M007;
      SET   ;
      R     #TEMP6.TEMP14;
      L     0;
      T     #TEMP6.TEMP16;
M007: NOP   1;
NETWORK
TITLE =
      A     #TEMP6.TEMP20;
      L     0;
      JC    M008;
      A     #TEMP6.TEMP20;
      L     1;
      JC    M008;
      A     #TEMP6.TEMP7;
      AN    #TEMP6.TEMP20;
      L     2;
      JC    M008;
      AN    #TEMP6.TEMP7;
      AN    #TEMP6.TEMP20;
      L     3;
      JC    M008;
M008: NOP   1;
      T     #TEMP6.TEMP15;
NETWORK
TITLE =
      AN    #IN0;
      JCN   M005;
      A     #TEMP6.TEMP19;
      =     #OUT4;
M005: NOP   1;
NETWORK
TITLE =
      L     LD     0;
      T     #IO5;
END_FUNCTION
almaz78
Re: WHAT DOING THIS BLOCK ?
Post by almaz78 »
i just looove your question:)
SHKODRAN
Post by SHKODRAN »
When one programmer starts a function with this statement....
      L     1;
      L     2;
      *I    ;
Rex2701
Post by Rex2701 »
Comments are in сzech language, but the code looks like it was written by a Hindu.
milhaushk
Post by milhaushk »
we have this code in one machine.
The function is referenced to tap the functions.
Here is calling.
       CALL FC 1
        IN0: = M7.0
        IN1: = 120
        IN2: = DB40.DBX0.6
        IN3: = DB40.DBX0.7
        OUT4: = DB41.DBX1.2
        IO5: = DB2.DBD0
