Good morning
I have a project running on an industrial PC with installed winc13 sp1 advanced runtime.
I want to syncronize the PC date and time with the plc, the plc is also in my project so I can find directly the variables into it.
I have used the "DATE AND TIME" field under the connections window, to declare how runtime can find the plc date and time.
The same project works fine if I use a Comfort panel, so I suppose it's windows on PC panel, that cannot allow to syncronize the date on time on operative system.
Thanks in advanvce
JS
						[?]: Wincc13 SP1 advanced - syncronize time PC-plc
				jonnystekkino1
				VTRT
Re: [?]: Wincc13 SP1 advanced - syncronize time PC-plc
Hi.
See the tab "Area pointer" in Connection to HMI (Data/Time &/or Data/Time PLC).
				jonnystekkino1
Hi  VTRT
Thanks for your reply, I have already used this area.
but doesn't work, it's so strange....
I have used the same project on Confort panel and works, without problems...
But if I use the project as a runtime on a PC, the date isn't syncronized and I have the following error code
date/time cannot be set, error code 1314,1
