I have an machine with XBT-P021010
I need software for making backup of actual program and put back this backup for other panel in better condition.
I have made i trial with XBT -L 1000 V4.42( this i have , and i get " transfer failed" when i try it to import the program.
Is there needed other software ? Panel is 6.98( that means 06 month from 1998)
Thank you in advance for help
Magelis XBT-P021010
Re: Magelis XBT-P021010
First of all you should install the latest version of XBT-L 1000 which is 4.51. If the problem still exist then you should install all the necessary drivers during XBT-L setup or from menu File -> Install Protocol. For example Unitelway, Unitelway 1, modbus, modbus plus, modbus slave etc etc.
