ET200SP - Modbus RTU with 20 Slaves
LKMNVRS
Post by LKMNVRS »
Hello Forum,
I am having S7-400H Connecting with ET200SP through Ethernet & 1 Modbus Communication Module (6ES7137-6AA00-0BA0).
I am having 20 devices of 3rd party as slaves, which I need to communicate with them through Modbus RTU - RS-484 - 2 Wire mode.
I had only 1 clarification, all the devices I connect are of same baud rate & same communication settings. So, I will use 1 - Modbus Comn Load (FB640) & 20 Modbus Master blocks (FB641).
For every, Modbus master block, there will be an DB generated & that DB need to be linked Modbus Comm Load (MB_DB) parameter. So, for other 19 DB, where i need to connect to MB_DB
OR
I have to call 1 Modbus Cmn Load & 1 Modbus master as an set of 20.
please help...! (sos) (oo) (h)
If any sample program for communicating with Multi request...Please provide
capsute
Re: ET200SP - Modbus RTU with 20 Slaves
Post by capsute »
same db,different device ID.
SHKODRAN
Post by SHKODRAN »
Hello everybody.
I have neeed too the library modbus rtu , can someone share ?
Thanks in advance.
Regards.
