[?]: CPU 414-2 After power supply ''off'' is lost project
Vital864
Post by Vital864 »
After power supply ''off'' is lost project.
The battery is new.
What could it be?
Re: [?]: CPU 414-2 After power supply ''off'' is lost projec
CPU old ?
Firmware version ?
https://support.industry.siemens.com/cs ... 0&lc=en-WW
Use memory card
https://support.industry.siemens.com/cs ... s7-400-cpu
use external backup power
On the front side of the S7-400 CPUs, you have the possibility of supplying a DC voltage of 5V to 15V via the "EXT.-BATT." socket. This provides a backup supply for all the slots in the rack. This external power supply is not monitored by the CPU.
Note
More information on external backup power supplies is available in the device manual "S7-400 CPU Data" in Entry ID: 23904550.
Vital864
Post by Vital864 »
1.Changed the firmware to the new one.
2. Memory card new. Have used on other CPU. There is no problem.
3. Connect an external power supply for 10 volts.
The problem remained. Where can you find a schematic diagram for the Board?
Vital864 wrote:The problem remained. Where can you find a schematic diagram for the Board?
no schemes :(
only photo http://s7detali.narod.ru/S7_417/S7_412.html
Siemens does not repair them - changes to new board
