Hi everybody
I need to migrate my project in panel builder (panel view550) to panel view plus 600.
Can someone help me please?
tkx
						migrate from from panel view 550 to panel view plus 600
				omark
				Ryzhij
Re: migrate from from panel view 550 to panel view plus 600
"for the labourer is worthy of his hire"(Luke 10:7)
What do you suggest?
				omark
sorry I dont interstand, what do you want to say?.Ryzhij wrote:"for the labourer is worthy of his hire"(Luke 10:7)
				Ryzhij
You really do not understand what serious work requires a serious approach, and must be paid?
How much are you willing to pay for this work?
				wildpikachu
Hi Omark,
In simple terms.
1)Save the panelBuiler32 file as a .PBA file.
2)import the file into factoryTalkView by creating a new project and selecting import.
3)pay attention to any errors listed when the conversion completes and correct them.
4) check each page to confirm operation and styles - pay special attention to text size and numeric entry points.
5) create you project path for RsLinx Enterprise - make sure that your DF1/DH485/DH+ settings are correct.
6) compile the application and download to your new panelView Plus 6 600
I assume you meant the panelView Plus 6 series HMI and not the panelView Plus series as the standard panelView Plus series is no longer available (at least here).
http://literature.rockwellautomation.co ... _-en-p.pdf <-- link to the migration guide
http://literature.rockwellautomation.co ... _-en-p.pdf <-- link to the catalogue migration guide.
Cheers
						In simple terms.
Cheers
				omark
wildpikachu wrote:Hi Omark,
In simple terms.
Cheers
Hi wildpikachu,
Thank you so much for your answer
The problem that i had is how to open panelbuilder file in factoryTalkView but after your explication i understand and i well do that after download and install factoryTalkView
thank you again
				omark
I’m ok with youRyzhij wrote:You really do not understand what serious work requires a serious approach, and must be paid?
But normally there some Tricks in ALLEN Bradley software can do this work.
