Is there a way to get Siemens RTX-F 2010 working on a PC when IRQ8 is allocated to "high precision event timer" and not to "real time clock"? with a computer with ACPI? Ive tried to change HAL, But cannot find one for ACPI uniprocessor (using AMD C60 processor but don't want to tie both cores up as only using to test my own programs.
Thanks,
Garry.
[LINK]: Siemens RTX-F 2010 IRQ
hardprogger
Re: Siemens RTX-F 2010 IRQ
Hey Garry,
it's not fitting for your topic, but can you provide the RTX-F iso image (installer)?
gazzap
Give me a couple of weeks to do this. I will sort out a file sharing account and we are awaiting a fibre connection (to save hours as file is a couple of Gig)
Regards.
Regards.
gazzap
### FOR TESTING ONLY ###
Link to Zipped files. WinAC-F 2010 V4.6 SP1.
mega
Download and unzip all to the same directory. Hope the link works. First time using this method.
Anyone have any ideas on the above question re: IRQ8 real time clock? You need to read release notes if installing on single processor PC as changes to the PC's HAL may be required for uniprocessor HAL.
hardprogger
Thanks for uploading the files. Now I have a running test enviroment.
ritvarsrizikovs
Made installation of Your software.
Works great!!!
Works great!!!
Majidhd
Re: [LINK]: Siemens RTX-F 2010 IRQ
Hi sir how to crack WinAC RTX F ?
thanks
thanks
hieuanhdo
Hi sir,
could you please share the Winac RTX F again, your link is empty
