Fatek plc cable drivers
другие контроллеры
dimz
Post by dimz »
I need the drivers for Fatek plc programming cable. The cable type is FBs_U2C_MD_180. Are the drivers compatible with winXP and win7?
Schtiel
Post by Schtiel »
Have you tried PL2303 drivers?
vlad2006gr
Re: Fatek plc cable drivers
Post by vlad2006gr »
FBs_U2C_MD_180-communication converter cable with standard USB AM connector to RS232 MD4M connector (used in standard PC
USB to FBs main unit Port0 RS232). You can use the USB converter in RS232,
for example UPort 1110 - http://www.moxa.com/product/UPort_1110.htm
1-port RS-232 USB-to-serial converters.
Pinout Fatek Port0 RS232 - http://www.thaiservo.com/thaiservo/User ... manual.pdf page 191.
dimz wrote:Are the drivers compatible with winXP and win7
-yes.
Drivers XP- http://www.esea.cz/support/fatek/PL-230 ... taller.exe
Drivers Windows Vista, Win7, Win7(64bit) -
http://www.esea.cz/support/fatek/vista- ... apters.zip
http://files.beijerelektronik.com.tr/do ... dows_7.zip
http://files.beijerelektronik.com.tr/do ... dows_8.zip
