Hello.
I need your help to answer the questions:
When the Simatic S7-300 is operating normally, with the key in RUN mode, and there is a power failure CPU (POWER OFF).
When you return the power to the CPU (POWER ON)
What will be the status of the CPU?
It returns to RUN?
The CPU requires a RESET to return to RUN mode?
This behavior can be parameterized?
When there is remote racks communicating via PROFIBUS, the CPU behaves the same way?
I appreciate the support of this forum so helpful to us.
SIMATIC S7-300 in MODE RUN after POWER OFF.
Rogertecn
Rogertecn
Re: SIMATIC S7-300 in MODE RUN after POWER OFF.
Diagnostic buffer
