currently working on the communication with videojet 1620 printer (Continuous Inkjet Marking), in there operators manual (http://www.videojet.com/content/dam/Cou ... Manual.pdf) the say :
- How to Configure Ethernet Port
Refer to WSI/ESI Communications Protocol addendum for more
information.https://fr.scribd.com/doc/180020947/Vid ... I-Protocol
I'have try it with th eprinter using the Ethernet port and all i can find open is the FTP(21), 3000, 3001 and VNC(5900). An d i have send same packets from the WSI/ESI to the print via 3000 and 3001 with Packet Sender but the response was empty!!
is there any one that know this protocol ESI/WSI or did work with this printer or simillar ?
i found this info in the FTP folder :
<?xml version="1.0" encoding="utf-8"?>
<CONTROLLER_INFORMATION>
<START_DATE date="07/09/2016"/>
<HARDWARE BoardType="CSB4"/>
<VERSIONS>
<WINDOWS_CE Eboot="4.0.3" CE_Image="2.0.9"/>
<SOFTWARE Type="Excel" Version="1.0.423.0" SVN_Build="28116M"/>
</VERSIONS>
</CONTROLLER_INFORMATION>
