RSEmulate 5000 wont install.
I have tried installing rsemulate 5000 v20. i have rslogix v11,15,19,2,0,21,23,26,28 installed. Each time I try to install it, I get an error when it goes to install the eds files. After acknowledging the error, the install completes. The program does not run correctly and all the modules do not show up, just the emulator cpu and an i/o module to select from. I am installing this on win 7/32 in vmware. I do a snapshot and install and it doesnt work. i tried another install that installs all versions from 12-21. same thing. Any suggestions or thoughts.
Re: RSEmulate 5000 wont install.
You need to have RSLOGIX 5000 v20 if you will work with RSEMULATE 5000 v20. Try it
I have v20 installed. Thank you.
Try it on Windows Xp SP3 (in VMWARE), probably you don't have Service pack 1 in your Windows 7.vatodster wrote:I have v20 installed. Thank you.
Read the next information about it:
http://www.ab.com/en/epub/catalogs/1276 ... ments.html
SP1 is already installed. Also meets the recommendations. I'm at a loss.
vatodster wrote:SP1 is already installed. Also meets the recommendations. I'm at a loss.
Do you have the same problem yet?
