I am using Profibus for the first time, previously mostly worked on ModBus.
Need to establish communication between TeSys-t (Motor Management Relay) & Profibus Remote Master (i.e. TCSEGPA23F14F) via Profibus DP.
I have the following quires, If anyone can help me out.
1) I have DB9 Female connector in both devices, what are standard pin-out for Profibus Communication.
2) Is it possible to connect devices directly via DB9 Male Connector, or I need specific Siemens Connector.
3) What are the recommended number of devices in each loop, Profibus Remote Master is supporting upto 125 in the configuration.
4) What are the limitations of Profibus?
5) Can I have multiple masters on a Profibus Network?
Hope I will get the answers of all above questions.
Regards,
Farhan Ali
[Support] Profibus Communication Basic Questions
Re: [Support] Profibus Communication Basic Questions
Hello Ali,
I will try to answer some of your questions.
You don't need to know pinout, just open the DB9 profibus-connector and you will find only 2 color marked pins suitable for profibus cable.
Yes, you can use DB9 non-Siemens profibus-connectors but End-connetors must have terminators.
Up to 125 devices.
https://en.wikipedia.org/wiki/Profibus
normally no, but some Siemens masters support 2xMaster configuration
Up to 125 devices.
Hello SE_support!
Thanks for the reply, you have cleared my doubts.
Do you have any application note regarding configuration and use of "TCSEGPA23F14F"?
Regards,
Farhan Ali
Regards,
Farhan Ali
Hello Ali,
try to find anything by using google. I know this module very good, so I'm able to let it work with closed eyes
