Linx printer Sure fill code and Easi-change code
другие контроллеры
Serobe
Post by Serobe »
Who does have expierence with codes for Linx inkjet printer. I have a linx 7900 printer.
Can someone help me out with codes for ink 1240 and codes for the solvent 1512
(fback)
codingstar
Re: Linx printer Sure fill code and Easi-change code
Post by codingstar »
I can help you.
Coincidentally, I have in my company 2 bottles of Linx.
Ink 1240: 27.10.2016 7SF-M26-GKE
Solvent 1512: 13.05.2017 62Q-JUU-D27
I do not have other option.
:anon: To all:
We can try to organize a swap meet for Linx and Domino codes.
Greetings from Germany. Service for Domino, Videojet, Linx and other.
Franc88
Post by Franc88 »
Hello CIJs!
We decrypted those codes.
I can generate any Quality Code QC for Domino A Series, A120 A220 and A+
Also I can generate Linx CJ400 5900 7900 Surefill codes and Maintenance / Service Passwords , send me the PRC code then I generate the password.
Linx 8900 8920 8940 Linx 10 , Linx 8820 8840 codes and Rfid Tags also
please email me inkjetprinter@protonmail.com (I look this email each 10 days )
For Domino Ax Series ax150i also I have a solution.
Regards!!
nikitakrup
Post by nikitakrup »
GOOD AFTERNOON! HOW DO I GET THE CODE FOR THE LINX 5900 PRINTER?
DimaR
Post by DimaR »
Hello Smart People!
By Links5900 and the entrance to the service.
The goal is to reset the blocking Filters and maintenance. (different paths) :
1. Drain into the USB installation and then turn off the battery on the board for 2 minutes, turn it on (we erase the volatile memory), fill it back with the USB installation and rejoice! . 2000 hours will be unlocked - this way works and is not very interesting (you don't need to enter any codes).
2. Using special commands through the PC 232/485 from the computer, we enter the service mode on the links 5900 - in the service documentation there are only 2 words about this method and there is no information on how to connect and what commands to send. In this "possible" mode, no codes need to be entered. This method is interesting - but where can I get more information? (example there you can change the system date)
3. We enter the service mode with the help of the USB with the .lsk file recorded on it 32 bytes of information and the name is 50104221 (where 16 bytes of the same type of information and the other 16 bytes carry the access code). Not all 5900 printers will fit this file ( written in the service documentation ) . It can be generated knowing the PRC. But where can I get such a code generator? IT analysis of many combinations for 100 years will break this code. This path is interesting - we are working on it.
4. The daily code entered from the keyboard to access the Service Mode is also generated based on PRC. - It's not very interesting, but maybe it's easier to get access to enter the filter code.
What are your thoughts on this?
Good Luck !
Ankita sharma
Post by Ankita sharma »
Dear all please give the solution for domino AX series printer RFID .
Artem_vlg
Post by Artem_vlg »
есть решения
Artem_vlg
Post by Artem_vlg »
Ankita sharma wrote: Wed Jul 27, 2022 6:08 pm Dear all please give the solution for domino AX series printer RFID .
есть решения
