[?]+: Need key for Web Navigator 7.4
billyY
Post by billyY »
Cant find a Liscence that will work with wincc webnavigator 7.4
any one able to help
xuanbach1985bk
Re: Need key for Web Navigator 7.4
Post by xuanbach1985bk »
Same problem! Anyone please help us, Thanks so much!
screencopy of ALM and C:\Program Files (x86)\SIEMENS\WINCC\diagnose\LicenseLog.xml ?
viewtopic.php?f=4&t=11415
xuanbach1985bk
CoMod wrote:screencopy of ALM and C:\Program Files (x86)\SIEMENS\WINCC\diagnose\LicenseLog.xml ?
Hi, thanks Mr Comod! This is my problem and LicenseLog.xml file:
http://www.mediafire.com/download/pkhcx ... nseLog.xml
Thanks and best regards
try one of SiFCYA9WSN9999*
viewtopic.php?f=4&p=76242#p76242
xuanbach1985bk
CoMod wrote:try one of SiFCYA9WSN9999*
Hi, thanks so much!
This problem is solved!
Homeroid_BL
Post by Homeroid_BL »
But where you can download Web Navigator V7.4?
Thanks!
Homeroid_BL wrote:But where you can download Web Navigator V7.4?
is a part of WinCC package
WinCC_v7.4\InstData\WebnavigatorServer
WinCC_v7.4\InstData\WebnavigatorClient
Homeroid_BL
Re: [?]+: Need key for Web Navigator 7.4
But, can I use Web navibator 7.4 from WinCC, with WinCC in TIA portal V13/14?
Homeroid_BL wrote:But, can I use Web navibator 7.4 from WinCC, with WinCC in TIA portal V13/14?
But you khow what WinCC 7.4 incompatible with with WinCC Professional in TIA portal V13/14 (h) (sfaq)
and use different keys in some case (boom)
Homeroid_BL
Yes, I know. But how to find Web Navigator V13/V14 for TIA? Noone here ever mentioned it. There are no links/torrents for downloading it.
Homeroid_BL wrote:Yes, I know. But how to find Web Navigator V13/V14 for TIA? Noone here ever mentioned it. There are no links/torrents for downloading it.
Unpack ALL TIA packages to folders and see
