connect with visualbasic.net with plc S7-1200
tyty
i want to connect with visualbasic.net with plc S7-1200 through a network ports? Thanks
TaaviM8x
Re: connect with visualbasic.net with plc S7-1200
http://www.deltalogic.de/products/software/accon-aglink
That demo works just fine enough.
Only limit as far as i remember is that it does deploy a popup on the beginning of the connection.
It's hard to get started though. Follow the Demos and its built-in AG help software (whatever the name was) which is describing all the functions.
There are also some samples and so on.
Having a history for several applications with aglink i can assure that this software is absolutely powerful enough to fulfill all your needs for a long future to come.
try to convert yourself from vb.net to C# though.
You can thank me later.
AndyRu
Interesting.
I got a previous version in demo mode that seems fully work.
