concept 2.6 xl crack
другие контроллеры
ahmad_maheri
Post by ahmad_maheri »
hi..
how i can crack the concept2.6 xl ? last solution dont work for me.. pleas help to me
Schtiel
authorcc.dat
Post by Schtiel »
ahmad_maheri
Re: concept 2.6 xl crack
thanks for your answer but that links dont work cuz they are too old pleas upload again consept2.6 xl crack or crack file ... pleas .. pleas
ahmad_maheri
pleas... i am hurry
ahmad_maheri
Thanks for your concept crack link, it is working perfectly. thank you very muchhhhhhhhhhhhh
ahmad_maheri
when i use of serial port on pc i can connect to cpu( 984e-285) but when i use of laptop and usb to serial covertor i cant conect to cpu why?
Schtiel
Post by Schtiel »
may be
ahmad_maheri wrote:usb to serial covertor
isn't operational or is a low quality converter, try another one
ahmad_maheri
I try to connect the Modbus online, with the cables RS232 correctly set, but it doesn't work, and jump out a message saying:
"Timed-out waiting for response from controller.
Error Id: OL9-1501"
what is the problem?
ahmad_maheri
the problem was solved ......i can change port setting and slove it
thank of all
