RSEmulate 5000 doesn't support the modules used on ControlLogix/CompactLogix. You only have a virtual digital module, no analog module.
If you need to test analog signals, try:
a) SoftLogix (I think RA is not developing it any more).
b) Write some logic to simulate internally the analog signals.
c) You can write values from a .MER project (Panel View project) running on the same computer where is running the emulator.
