[?]: PC Software CPU 1505s/1507s
pedro4321
Hello everyone.
Can some one point mi to the installation media of CPU 1507s?
i'd like to test it.
Beavis
Re: [REQUEST] CPU 1507s: Me too!
The product code is SIMATIC SOFTWARE CONTROLLER CPU 1507S DL (6ES7672-7AC00-0YG0)
If anyone has it, please upload it!
CPU 1507s =1505S
about https://support.industry.siemens.com/cs ... controller
link https://support.industry.siemens.com/cs ... ti=0&dl=en
CPU 1505S - PREINSTALLED ON ET 200SP OPEN CONTROLLER
https://support.industry.siemens.com/cs ... -cpu-1507s
SIMATIC S7-1500 Software Controller Additional Information on CPU 1505S/CPU 1507S
1507S ON DVD SIMATIC_CPU1505S_V1.8.1.iso (589,2 MB)6ES7672-5AC00-0YA0
SIMATIC S7-1500 SOFTWARE CTRL CPU 1505S
SIMATIC S7-1500 SOFTWARE CONTROLLER CPU 1505S VERSION 1, SINGLE LICENSE F. 1 INSTALL, R-SW, CLASS A, 6 LANGUAGES: GE,EN,IT,FR,SP,CH;
For install on PC it required 2 partions on disk6ES7672-7AC00-0YA0
SIMATIC S7-1500, SOFTWARE CONTROLLER CPU 1507S VERSION 1.8, SINGLE LICENSE F. 1 INSTALL, R-SW, SW AND DOCU.
ON DVD, LICENSE KEY ON USB STICK, RT-SW CLASS A, 6 LANGUAGES (GE,EN,FR,IT,SP,CN) EXECUTABLE UNDER WINDOWS 7 REFERENCE-HW: SIMATIC IPC4X7D, IPC6X7D, IPC8X7D
Creation of the CPU volume
Introduction
The CPU makes use of the mass storage of the PC on which it is installed. During the installation, a discrete CPU volume is
created in the mass storage, in which all CPU data is stored. The load and retentive memories are integrated into this CPU
volume.
Note
Size of the CPU volume
In order to ensure reliable operation of the CPU, the CPU volume must not be reduced during operation. If you reduce the
assigned mass storage area, this can lead to data loss or even a CPU crash.
capsute
is it possible to intall SIMATIC_CPU1505S_V1.8.1.iso (589,2 MB) on a normal PC?
IF YES,HOW?
IF YES,HOW?
capsute
After installing the SIMATIC_CPU1505S_V1.8.1 on normal pc,I got a error screen saying fatal error unsupported pc type,how to solve this problem.
pedro4321
Yes, correct. thats what happen with 1505S. I was successful removing that alarm modifying the bios in a virtual machine but after that i got another cpu error message.
Thats why i was looking for the 1507S iso.
capsute
Re: [?]: PC Software CPU 1505s/1507s
If you get it,and eventually make it run on normal pc,don't keep it.
yanzixiang
can u share the method how to modify ths bios in the virtual machine ?pedro4321 wrote:Yes, correct. thats what happen with 1505S. I was successful removing that alarm modifying the bios in a virtual machine but after that i got another cpu error message.
Windoze
I uploaded 1507S here: viewtopic.php?f=30&t=24416
Please share your method for modifying the virtual machine bios
hardprogger
I'm also searching for a method to run the controller on vmware.
yanzixiang
if we want to modify the bios of the vm,Windoze wrote:I uploaded 1507S here: viewtopic.php?f=30&t=24416
we need the bios information of a running IPC which 1507 runs on,
use the tool
http://gnuwin32.sourceforge.net/packages/dmidecode.htm
to dump the bios,
then ........
can u have a simens IPC which runs 1507 software CPU?
if u have, can u use hexedit to dump the CPU volume to a file?
Windoze
Sorry, I don't have access to a compatible Siemens IPC...
Info
- Faq & Info
yanzixiang
Windoze wrote:Sorry, I don't have access to a compatible Siemens IPC...
Microbox PC IPC427D
Box PCs IPC227E, IPC627D and IPC827D,
Panel PCs IPC277E,IPC477D and IPC677D
Rack PCs IPC647D and IPC847D
the cheapest one may be IPC227E.
at this URL,
https://support.industry.siemens.com/cs ... 0&lc=en-DE
we can download the Latest BIOS file,
can u upload the file?
Windoze
The smallest one supported seems to be the SIMATIC IPC427D.
I have uploaded the latest bios for it here:
https://mega.nz/#!0ZcHkA4D!0w_bt6BTw0XM ... DP17Ssvvk4
yanzixiang
thanks a lot!
another error occurs.
i thanks it must be about the CPU volume.
Windoze
Can you tell me what you have modified in the vmware bios. I want to experiment a bit myself.
Windoze
I am using VMware so I had to change the DMI strings in the BIOS file.
Before I got the same "Unsupported PC type" now I get a different error:
yanzixiang
how many cores do you set in the vm?
when i try to set 2 cores in the vm,
i get the error as you post,
after i change it back to 1 core,
my error occurs again.
Windoze
I only tried 2 and 4 cores.
You need at least 2...
1 core for the cpu, the rest for windows
yanzixiang
What does "module +16" mean in Grub4Dos?
What is "{FBBDD621-CB50-491C-986F-F05B42E80B95}"?
Anyone can help ?
vrman
Description is here
13.3.25 module
— Command: module file ...
Load a boot module file for a Multiboot format boot image (no interpretation of the file contents are made, so the user of this command must know what the kernel in question expects). The rest of the line is passed as the module command-line, like the kernel command. You must load a Multiboot kernel image before loading any module. See also modulenounzip.
yanzixiang
that is right,but i already know about it, the manual does NOT talk about "module +16".
yanzixiang
After modify some parts of the kernel,
I can this error
Left image is the real PC,right image is the virtualbox,
The real PC supports VT-X,but the virtualbox does NOT.
As we can NOT run a virtualbox in a virtualbox,
We can not test 1507 on a virtualbox either.
We must use a real PC.
I can this error
hardprogger
Which modifications on the kernel have you done? Can you provide some detailed information/files?yanzixiang wrote:After modify some parts of the kernel....
I'm playing arround with Vmware and I saw that I have VT-x support inside the virtual machine.
But my problem is, that I have an hardware error on core 0 at startup.
The error with the manufacturer is already fixed.
Beavis
Got any progress using a vmware image?
Did you get a working bios? can you share some details
thanks
John
thanks
John
yanzixiang
some guys asked me what modifications have I did.
I disassembed the kernel,
and guese where to modify,
up to this time,
I failed.
There are so many tests,
and i have no clue.
If we can have one running BOX in touch for test,
maybe we can make it.
I upload the modified kernel files,
if u guys want to test it ,
please backup your vmm.elf and replace it with my vmm.elf.
If u have good luck,
let me know.
链接: https://pan.baidu.com/s/1o8NcVLw 密码: err6
up to this time,
I failed.
and i have no clue.
let me know.
Beavis
Hello.
I tried your elf but got no result (fatal error or crash)
I guess you used a custom bios for the virtual machine (otherwise you might get "unsupported pc type").
I used a tweaked version of FUJITSU211_314.ROM (the Bios file I used for WinAC RTX under vmware) and replaced the "vmware" vendor strings with "siemens". With that I got past the "unsupported pc type" but got other faults.
What "bios" file did you use?(under entry "bios440.filename=" inside the vmware .vmx file)
In one of your screenshot i saw an error "vmx disabled"..... that error theoretically can be avoided setting the setting "Virtualize intel VT-x/EPT" setting... did you try that?
bye
john
bye
john
yanzixiang
I used a REAL pc box.
I have knows about the setting "Virtualize intel VT-x/EPT" already,
Thanks.
Thanks.
lazik
Must try with v2.0 ISO. On OpenController eveything works fine.
delege
Can someone post the 2.0Iso and a workaround to run it on vmwaRE?
Zonki
could somebody point me to the download of the CPU1507S V2.0, i search already days bu didnt found. I like ti install this and test it. Same like with the Runtime of WinCC V14.
Thanks a lot.
Thanks a lot.
hardprogger
I'm also searching for the latest CPU1507S V2.0 ISO image. Is nobody here that can provide the iso?
asdsoft
Ernie29
Actually it´s not possible to get it running on "normal" PC.
Tested with V2.0 ISO on "normal" PC (not dedicated SIMATIC BOX PC)
delege
i guess, there are not other news to run this on a non-simatic pc?
hanjinxing
https://support.industry.siemens.com/cs ... S_V2_1.exe
There is a new version of V2.1, the friend can help download, I can not register Siemens Global Center account, I will express my thanks!
Update
- Forum Community
hanjinxing
The link I can not open, can help provide other download links? Express thankfulness!
hanjinxing
Thank you everyone! China is a large local area network, individual rights have been deprived
Link
- Forum Community
- Location: We are anonymous users. We do not read your private messages :( Ask questions in the forum !
hanjinxing
Thank you very much! The The
capsute
It seems that v2.1 need a new authorization,the latest Sim_EKB_Install have not had it yet?
Update
- Forum Community
hanjinxing
After installing the new license, the same problem
Ctrl+Alt+Del is not problem of new key
amarillo
Is this thread dead? No more trying to make it work under VM or regular PC?
Amarillo
Amarillo
Dr.Acrobat
News about it ?
Thanks.
Thanks.
