Hi all,
Can someone create a project in step 7 with an ET200S CPU (IM151-7 6ES7 151-7AA10-0AB0), download the project to the MMC then create a binary image of the MMC?
I set the wrong baud-rate on my project for the MPI connection and downloaded it, now I can't access the CPU as my MPI USB cable can't support the baud-rate.
Hopefully I can write the binary image to the MMC and reset the default MPI settings.
Thanks for your help.
[?]: Siemens MMC Image for reset MPI settings
Firetramp
Re: Siemens MMC Image - Request
Your card size and 6ES7953-?????? number ?
http://s7detali.narod.ru/MMC/MMC.html
Firetramp
Oops, sorry.
64KB MMC with part number 6ES7 953-8LF20-0AA0
Re: Siemens MMC Image for rest MPI settings
Oops, sorry...Firetramp wrote:Oops, sorry.
I have
64 KB 8LF11
128 KB 8LG11
512 KB 8LJ30
Need your configuration: CPU->PM-E>Input modul
Firetramp
Re: [?]: Siemens MMC Image for reset MPI settings
Just the IM151 in the project will be fine. It's for a PLC I have in the house for testing so I can add the IO modules later. If you can try with the image of your 64k and maybe it will work?
Thanks again.
Thanks again.
