Good day dear collegues. I try to create programm inside ACS880. I would appritiate if you give me some reference to the drive application programming license. Is it free of charge of it costs something? If it is free can I download it somewhere?
Thanks a lot in advance!
						Drive Application Programming
				Carlos
Re: Drive Application Programming
you need Drive Composer Entry, it is free, just use a USB cable to USB mini and drive Assistant Control Panel (ACS-AP-I/S) USB Driver
can also use the drive console (keyboard)
If you use Drive Composer Pro you have one month free
carlos
carlos
