[?]: STEP5 V7 Yellow Disk Image
nickds
Post by nickds »
Does anyone have a Yellow Disk Image for STEP5 V7 authorization?
Many thanks,
Nick
Re: [?]: STEP5 V7 Yellow Disk Image
try EKB_Install or Siemens.exe for install key A1S5BP70.EKB SIK/SIMATIC STEP 5/ST BASIS V7.0
viewtopic.php?f=30&t=218
for install STEP5
Install ID Number wrote:name: admin
Install ID: 0072035001
use EKB_Install for create valid Yellow Disc and original AuthorsW for move key to discette
ALMx64 not support short keys (h)
nickds
Post by nickds »
Thank you, I have got a Yellow Disk image with all keys on it, but when I try to transfer key using DOS authors.exe I get an error. I am using VirtualBox and a .IMA file of the Yellow Disk.
And a problem with Windows 95 and AuthorsW
Many thanks
Direct install on VirtualBox - tested
ALMx32 support short keys (thnx)
Step5 work on WinXP (suc)
viewtopic.php?f=30&t=13500&p=37303#p37303
SIMATIC STEP 7 V5.5 SP4/ STEP 7 2010 SR4 Professional - PG Edition with MicroWin for Win7 and Step5 for WinXP
https://mega.nz/#F!DsE1RDSB!Zk1D6fE-nuBGXJF74ZFGLA
nickds
Post by nickds »
Thank you :)
It is a long story, but I am trying to install Step5 in a DOS only environment.
Can you give any advice on the best way to do this? Authors and AuthorsW have caused me problems.
AuthorsW and ALM32 can't write with VBox floppy driver (boom)
nickds
Post by nickds »
I tried with other virtual software and no luck writing to a floppy image :(
Is there a version of EKB_Install that works on Windows 95 or 98?
I can use Windows XP and install with EKB_Install and check with AuthorsW and the keys work, when I copy the AX NF ZZ folder to Windows 95, 98 or DOS it says the keys are faulty even though they worked in XP?
