we have a station with two redundant cpu 414-4H he first cpu is on stop and signal an external default, an automation think there is a problem in the cpu even if it does not display an internal error !!! !
me I want to know if this can happen and really there's a chance that the cpu is defaulting and ( he does not arrive to display the internal default ? )
the second question is if it is replaced by another of the same cpu reference of course , there's a chance that he can go to run , so that START confirmed what this person said on the first cpu ?
The error in the CPU 0 :
Spoiler
diagnostic Erreur :
Event 1 of 50: Event ID 16# 530D
New startup information in STOP mode
Startup prevented by:
- Module or submodule assignment not evaluated or evaluation aborted with errors (SDB 1,3,5,2X,9X)
- STOP request exists
- Cold restart or warm restart necessary
Startup information:
- Time for time stamp at the last non backed up power on
- Single processor operation
Current/last startup type:
- Warm restart triggered via MPI
Permissibility of certain startup types:
- Manual startup not permitted, corrections in parameter assignment, submodule, etc. necessary
Last valid operation or setting of automatic startup type at power on:
- No startup type/following memory reset
Operating mode: STOP (internal)
Incoming event
Incoming event
