Hi all,
I am looking for a low cost HMI.
What are your views/ opinions on KINCO, WEINTEK and SAMKOON etc?
Are they reliable and worth the money spent
Low cost HMI
krank
macedoethomas
Re: Low cost HMI
I would use DELTA as advice above , consider Weintek although I had some difficulty in use it, especially reading registers , inside Siemens PLC data blocks as DBDs.
Did you consider as option use PLCs with incorporated HMI?
Do you know Unitronics?
Regards ,
MTE
Regards ,
MTE
