I have 1 unit TP 900 Comfort and 1 unit PLC CPU Siemens 315-2DP.
The software that I have only Siemens Simatic Manager and WINCC Flexible 2008.
I have found that WINCC Flexible 2008 not support this TP 900 Comfort Panel.
May I know what other software I need to install to program this TP900 Comfort?
Thank you.
[?]: WINCC Flexible 2008 not support TP 900 Comfort Panel
mhi_rockerz
Rex2701
Re: TP900 Comfort
TIA Portal only
The Comfort panel line is configured with the engineering software SIMATIC WinCC V1* of the new Totally Integrated Automation portal.
mhi_rockerz
Re: [?]: WINCC Flexible 2008 not support this TP 900 Comfort
Let say if i install the new Simatic WINCC Version 1* (TIA Portal), create a new project file,
is that possible to link between my HMI to PLC which use the old Step 7 Simatic Manager Version 5.5?
Or i MUST to install Simatic Step V1* (TIA Portal)?
Info
- Faq & Info
Re: [?]: WINCC Flexible 2008 not support TP 900 Comfort Pane
https://support.industry.siemens.com/cs ... 0&lc=en-EN
mhi_rockerz
yes...thanks a lot..This info really helpful.
Can anyone give me download link for WINCC V 11.0?
I try to find it but still failed...
DiVan
Use v13 SP1 Update 5mhi_rockerz wrote:Can anyone give me download link for WINCC V 11.0?
Download Trial = Full version from Siemens http://support.automation.siemens.com/W ... /106567563
viewtopic.php?f=30&t=20958
