I'm new to AB PLC I have program running on AB PROCESSOR 1747-L542 with extension for the file .rss I need from AB expert necessary software to open it & print copy of the program on pdf , please can you send the links and activation for it as I saw that most links for AB software are not valid & dead on rapidshare
thanks
SLC-500 engineering software required
engineer66
Re: SLC-500 engineering software required
Post your file. You need to know what version you need to open the project file with. Having someone else open it and send you the logic will probably be faster
