Unlock Pro Face GP37W2
elcarnado
Post by elcarnado »
Hi all!
I need upload project from the HMI Pro Face GP37W2, without original project. But the project blocked on password in India many years ago. The password can be only digital from 1 to 4 symbol. I wrote simply program, which click on 'upload' button and then types number into textfield. If password is incorrect, program decrements it and type again. But program checked all possible password from 0 to 9999 and the correct password was not found. Can anybody hellp me, please?
I used python, PyautoGui(simulate keyboard input) and PyWin32(detect which window is open now).
Spoiler
Main Window - http://uploads.ru/BFM0O.jpg
Paswword input - http://uploads.ru/Ojt50.jpg
Incorrect password - http://uploads.ru/Sv5DP.jpg
Program output - http://uploads.ru/V8Xq1.jpg
Spoiler
import win32gui
import pyautogui
import time, os
RECEIVE_X = 965 #Coordinates X receive button
RECEIVE_Y = 60  #Coordinates Y receive button
def transfer():
    password = 9999 	 #Start password number
    w = win32gui
    while password >= 0: #End password number
        if w.GetWindowText(w.GetForegroundWindow()) == 'Save File':             #Window 'Save File' showing if password is correct
            break
        elif w.GetWindowText(w.GetForegroundWindow()) == 'Transfer':            #On Transfer Window click on 'Upload' button
            pyautogui.click(RECEIVE_X, RECEIVE_Y)
            time.sleep(8)											# time to connect HMI
        elif w.GetWindowText(w.GetForegroundWindow()) == 'Register Password': # In this window enter the current password
            time.sleep(0.2)
            print ('Try password %i' % password)
            pyautogui.typewrite(str(password), 0.1)
            pyautogui.press('enter')
            if password % 20 == 0:											# log in file
                f = open(u'D:\Proface_Brutforce\log.txt', 'a')
                f.write('Password = %i \n' % password)
                f.close()
            time.sleep(1.2)
        elif w.GetWindowText(w.GetForegroundWindow()) == 'Invalid Password!': #if password incorrect
            password -= 1
transfer()
device111
Re: Unlock Pro Face GP37W2
Post by device111 »
is the PAssword 0010 not working? Long time ago a had the same Problem and I think there was a Backdor for PAsswords.
If its not working, try to call Pro-Face...there will help you.
elcarnado
Post by elcarnado »
device111 wrote:Hi,
No, paswword 0010 is not working. The standart password 1101 is not work too. Thank you, I will rewrite HMI program (
hmohamed
Post by hmohamed »
Did you tried this website
http://www.ymmfa.com/thread-gkfid-37.html
they can have a solution for your problem
good luck
