Can not upload from CompactLogix L33 ERM
Buuu
Post by Buuu »
Can not upload from CompactLogix 1769-L33ERM
When I try - have error
What is wrong?
Rev of PLC 21.011
Windows 7 Pro
Studio 5000 Version 21.00
abdollahi
Re: Can not upload from CompactLogix L33 ERM
Post by abdollahi »
Hello
I have the Same Problem. ""(Unable to connect to controller.RSLogix 5000 support for this firmware revision is not installed. Controller Firmware Revision:21.11)""
I think it needs a higher Version of Studio 5000
Thanks.
Buuu
Post by Buuu »
abdollahi wrote:Hello
I have put the Download Link of Logix Designer Studio 5000 V26.01 :
http://www.4shared.com/rar/rxaxF_MGba/2 ... bpart2.htm
http://www.4shared.com/file/4taF0r5fba/ ... t1exe_.htm
It just needs being activated
Thanks.
thank You
I will try it
NowanH
Post by NowanH »
Buuu wrote:Can not upload from CompactLogix 1769-L33ERM
What is wrong?
Rev of PLC 21.011
Windows 7 Pro
1. If you want to go online with a *Logix PLC, the firmware versions of the PLC and Studio 5K have to match. A newer version of Studio 5K is able to open an older application but it needs to convert it to the newer version.
2. In versions prior to 20 you only needed to match the major revision. In version 20 and 21, you need to match major and minor revisions.
3. Please read this:
https://rockwellautomation.custhelp.com ... _id/565204
https://rockwellautomation.custhelp.com ... _id/582891
jobcreator
Post by jobcreator »
Can someone re-post a download link for v24? The ones above are now broken. Thanks!
