How I can reset locked memory card. I downloaded software and hardware to memory card which has password, and now my memory card is locked, and also plc is locked when memory card is in. Can I some how to delete everything from memory card?
PLC s7-400
clear memory card plc siemens s7-400
Ramomkosta
Re: clear memory card plc siemens s7-400
You can clear your Memory Card using a Simatic Prommer:
Manual:
https://cache.industry.siemens.com/dl/f ... _en-EN.pdf
Or a Notebook Siemens "Field PG":
Manual:
https://support.industry.siemens.com/cs ... nload=true
To Format, you can Use TIA Portal Software:
https://support.industry.siemens.com/cs ... 0&lc=en-WW
Or
A Simatic Manager Software:
Manual:
Manual:
Or
s7-400 memory card is Standard PCMCIA memory card - but need to remove the green cap from the top of the MC card
viewtopic.php?f=1&t=8254&p=19813#p19813
add
to PPP
viewtopic.php?f=1&t=17844
use old Step7 version 5.? with "unpassword" bug for read passworded MC
add
smb
Hi CoMod,
If I want to clear every thing from MC flash memory with PC and MCE. What should I do? MCE has an option to format of flash memory. Does it work or not?
Thx
Thx
