I have problem with intouch historian 9.0, the Intouch installed and communicating with OPC servers via FSGateWay,
the node successfully imported to HISTORIAN and HISTORIAN is working,
also InTouch is set as follows:
- put a tick "Enable Historiacal Logging";
- put a tick "Log Data" in all the right tags;
- distributed history is set to InSQL Provider
Further, the Historian was placed import tags from InTouch, which was chosen method of storing data "Cyclic Storage For All Topics" and put a period of 1 sec. All tags successfully imported.
The firewall is disabled.
yet no history saving,is there any setting require? What could be wrong?
