Hello everyone,
I'm working on FT ME v.7 (My setting are below) and I didn't insert any storage cards.
Max. data points : 1,000,000
Path : System default
Log Triggers : On Change, max update rate 0.05 sec, change % 1
Tags in model : total 12 tags
Do you think I can get the data Logging file out of the Panel View?
If I you think I can get that file could you please tell me how.
I'm appreciate all help in advance!
Thank you in advance!
[?]: How do I get data log from PVplus 1000?
lilengineer1987
NowanH
Re: [?]: How do I get data log from PVplus 1000?
In PanelView Plus 6 you can use the FTP server and DataStore PLus Activex. I'm not sure if it's possible to install DataStore Plus in PanelView Plus.
http://theautomationblog.com/rockwells- ... ew-plus-6/
lilengineer1987
Thank you so much!
I could did it by some posts over here.
If anybody need any help about this just msg me
