How to Install Simatic Step 7 tia Portal v 13 ?
ggg315
Post by ggg315 »
Hi I have downloaded this setup of simatic from the torrent ISO files ?
Please guide me how to activate the full lisence
Re: How to Install Simatic Step 7 tia Portal v 13 ?
[FAQ]: How unpack archive and CD-image (ISO, NRG) files
viewtopic.php?f=2&t=6036 (image dead [dead] )
Use UltraISO or Total Commander with ISO plugin for unpack to folder
anorexia
Post by anorexia »
Easiest way:
Use virtual clone drive. Freeware. (gogle)
After install the simulator(if you have)
Install the wincc (if you have)
Then install TIA Portal.
I advise you to install the service pack. After you installed, the TIA portal will faster, and there are less bugs. Less freezing.
Best Regards,
Anorexia
