Beause Siemens TD200 has been discontinued,I still need to use some of the machinery.I nedd td200 alternatives.Can anyone tell me what the product can replace TD200?TD200 alternatives need not be Siemens brand, but you can replace the TD200 and the complete program without modification S7200PLC and need CE and UL.
I found VIPA TD 03 Text Display but I'm not sure whether you can replace the TD200?
Siemens TD200 alternatives???
a151218
marbeno
Re: Siemens TD200 alternatives???
I confirm that the panel is the same. It is produced by Vipa licensed Siemens. Greetings
