[?+]: Station COnfiguration Editor show me this error
yacino
Post by yacino »
When starting the station configuration editor, this error appear :
error wrote:SIMATIC NET Core Server S7OPT
Configuration of the SIMATIC PC station is not completed! Running in DEMO mode.
i'm using the Simatic Net V12.
please can any one help me to remove it
Re: [?]: Station COnfiguration Editor show me this error
yacino
Post by yacino »
Thanks for the response,
this is the EKB install
i install the recomnded keys.
http://www.filedropper.com/ekb
the i reboot the computer, but i still have the problem;
this is what the ALM show me for licesne,
i think that the license of the SIMATIC Net is not installed , because there is only the 8.0 license as the picture below show:
http://www.filedropper.com/alm
You have installed ALL KEYS (h)
For Simatic Net V12 from TIA Portal need install v12 keys
For Step7 v5.5 need install 1 key from Net v6.*... to 8.2
yacino
Post by yacino »
(wow)
Thanks again ,
I download the SIM_EKB_INSTALL_2015.
I delete all the licenses key.
I reboot the computer.
I install all the keys again.
This is what the ALM show me:
but i have still the problem
yacino wrote:(wow)
Thanks again ,
install all the (boom) again
Install only 1 key for your Simatic Net version (warn)
Show ALM > Installed software folder
yacino
Post by yacino »
Hi
I hope that you're not tired for me, but this is what tha ALM show:
so the simatic net 12 license is installed correctly but it's still show me the demo mode.
Sorry for my questions
yacino wrote:so the simatic net 12 license is installed correctly but it's still show me the demo mode.
Key from 6.* can block key v12.
(sfaq) https://support.industry.siemens.com/cs ... d?lc=en-WW
How can you deactivate the Trial License when the message appears indicating that the Trial License has expired, although the Floating License has been installed?
yacino
Post by yacino »
thank you so much, the problem is solved. (tyou) (suc)
Regards
