invalid username or password -> intouch 10.1 sp3 [solved]
Suseh
Post by Suseh »
\hi everyone,
i try to install intouch 10.1 sp3 on windows xp pro with sp3.
When i am on screen where you should choose user account to run with intouch the intouch installer says that
i put invalid username or password.
It is confusing because i am sure that i put correct user name and password. There is only one user account (with administrator mode) on this computer.
Thanks for advice,
Suseh
[solved]
Confusing. Useraccount name in control panel is different from useraccount name in Account panel (control userpasswords2).
Anyway, after putting account name from account panel it starts to work.
vantaipc
Re: invalid username or password -> intouch 10.1 sp3 [solve
Post by vantaipc »
so easy
you open your project code then delete file "password.bin"
then you Runtime Intouch again login:
User: administrator
password: wonderware
you can fix it.
