Forgive my English and a little bad, how do I within a fc access a temporary array?
language: stl
statement: array data [1..100] of int
as I am trying to access
#data [#address]
Indexed access the temporary array within a fc
antonio
SHKODRAN
Re: Indexed access the temporary array within a fc
Hello ,
see the sample below:
L P##Array_Data // Start adress of 6 byte long pointer in memory
LAR1
L W [AR1,P#0.0] // load value of first Word in Array
L W [AR1,P#2.0] // load value of second Word in Array
L W [AR1,P#4.0] // load value of third Word in Array
etc.
ruzickja
One idea, but not tested:
In the standard library, there are very promissing blocks:
FC91 WRD_TBL
FC89 TBL_WRD
Other approach:
L #Index
SLD 4 //because the address is bit-oriented, so for 16-bit it is shift by 4 (*16), for 8bit it is shift by 3 (*8), DINT is shift by 5 (*32)
+D //Do the pointer arithmetics
LAR1 //Load the AR1 adress-register
L W [AR1,P#0.0] // load value of Array_Data[Index]. Note it is 16-bit INT. // For DINT it is L D [AR1,P#0.0]
FC91 WRD_TBL
FC89 TBL_WRD
Other approach:
L #Index
