I have got an issue. Does anybody knows if it is possible with Intouch to read a bit inside a byte tag like in WinCC? Example: I have a tag DB1.DBB2, but I only need to read the status of DB1.DBX2.5. How it is possible to do without creating a discrete tag?
Thanks!
Intouch Tags
Re: Intouch Tags
in expression you can use for example tagname1 AND 2**5
where tagname1 is the tag of DB1.DBB2
read this http://platforma.astor.com.pl/files/getfile/id/3887
Re: Intouch Tags
Thanks a lot, Cmos!
I think, you meant tagname1 & 2**5 and it works.
But now I have got opposite question. Is it possible to set/reset bit in byte tag?
Re: Intouch Tags
You can use bit fields with integer tags.
Thus, with an integer tagname "MyTag", MyTag.00 is the least significant bit and MyTag.31 is the most significant bit.
You can read or write the bit field :
IF NOT MyTag.05 THEN
MyTag.05 = 1;
ENDIF;
