[?]: cable for connect Magelis HMIGXO3502 to S7-300
omar zedan
Post by omar zedan »
Dear All
I want to connect Magelis HMIGXO3502 to S7-300 CPU (through MPI port or profibus port)
but the problem in cable (I should make DB9 female "connect in Magelis port 2" and DB9 male "connect in S7- 300 CPU") can any one help me by sending pin out of this cable?
Regards
Panda Gendut
Re: [?]: cable for connect Magelis HMIGXO3502 to S7-300
Post by Panda Gendut »
search SiemensMPIPPIe.pdf at
C:\Program Files (x86)\Schneider Electric\Vijeo-Designer 6.2\Vijeo-Frame\Help\ENU
You will get the wiring diagram.
Thanks.
