Magelis with S7-300
omar zedan
Magelis with S7-300
Post by omar zedan »
Dear All
I want to connect Magelis HMIGXO3502 to S7-300 CPU (through MPI port or profibus port) but the problem in cable (I should make DB9 female "connect in Magelis port 2" and DB9 male "connect in S7- 300 CPU") can any one help me by sending pin out of this cable?
Regards
gary_angel
Re: Magelis with S7-300
Post by gary_angel »
I found this manual(German language) - http://download.schneider-electric.com/ ... 002_04.pdf
omar zedan
Dear gary_angel
I read in some sites it is possible to connect the Magelis to S7- 300 cpu through profibus port using cable (just cable no adapter required) and I ask about the pin diagram of this cable, also I want to mention that the magelis HMIGXO3502 has DB9 male port (Port 2) can work as RS 485 and as you know the S7 -300 CPU has a female DB9 as profibus.
I want the pin diagram of this cable if it is available
Thanks so much
