VARIABLE NAMES TO ASSIGN MODE SIMULATION
In the simulation we have the option to PLCSIM variables that show the names assigned in the program. To do this we must go to TOOLS> OPTIONS> ASSIGN SYMBOLS and select the program table. We select DISPLAY SYMBOLS and now we insert BITS VERTICAL, which show below the name assigned in the project (PLC variables).
With TIA PORTAL gives the problem that is not active the option to select the variable table. Does anyone know why?
THANKS
VARIABLE NAMES TO ASSIGN MODE SIMULATION TIA PORTAL
HUESCAR
