FM 357-2 Flash card error no lenienceor incorroect lenience
mohdabshr
Post by mohdabshr »
dears,
we have machine with Fm 357-2 connected to CPU 316 and FM 357-2 give alarm SF when I used the Fm357-2 software the error is FM error(no lenience or incorrect lenience) and the flash card is original and working before, please I need your help how solve this.
thanks,
Re: FM 357-2 Flash card error no lenienceor incorroect leni
license ?
(sfaq) http://support.automation.siemens.com/W ... n/21385102
Under no circumstances should you use the SIMATIC Manager to delete or to write the memory card, because the license will be lost in this case !
For the update you require the original memory card of the FM 357-2 with the corresponding license.
Firmware and license must match, i.e. a firmware version LX will only work with a memory card with LX license.
Write to Siemens Support for restore license
equal for Simotion memory card
http://support.automation.siemens.com/W ... n/42614521
mohdabshr
Post by mohdabshr »
thank you very much coMod
did Siemens has link to restore FM 357-2 memory card as Simotion? if they have please give me the link.
