Hello All, I need a software to progarm a old controller back in the old times....I checked the controller model, and the software package needed must be either V5.0 or V5.0 SP1 that's the only software version contains that modular module, I no longer can find the software anywhere, please help!
Thank You!
[?]: How to programming old S7-314 ?
dekor
Re: Request: old STEP 7 V5.0 or SP1
it will be Ok for you S7 v5.0 sp3?
Check on link below.
http://www.fileshare.ro/e31127705
dekor.
dekor.
Tensaiga
I am not sure, the controller I am trying to connect to is a S7-300 CPU "314-1AE04-0AB0" according to this PDF file
https://mall.industry.siemens.com/Datas ... control%3E
Under Configuration software I could only use Step 7 V5.0 or V5.0 SP1.
Looks like I am running out of luck, but thanks for all your efforts !
Best Regards,
Best Regards,
use Step7 v5.5 SP4 for programming old and very old PLC - this is notTotalIA Portal
Tensaiga
That's awesome I really did not know you could do that, just curious however where can I download a version of that software you are just showing me? I just need it for this small project....
trying to save money for myself...
Thanks!!!
Thanks!!!
Tensaiga
Hello I have installed the software, however I am new to Siemens, I am not sure how you opened to that screen in your previous post, could you provide me with a step by step procedure?
Thanks so much!
Thanks so much!
Tensaiga
Never mind I have figured it out, but if you could provide me with an explanation on how to upload from the existing controller that would be great!
Thanks so much!
Thanks so much!
SIMATIC S7-300 SM331; AI 8x12 Bit Getting Started part 1: 4 -20mATensaiga wrote:Never mind I have figured it out, but if you could provide me with an explanation on how to upload from the existing controller that would be great!
http://support.automation.siemens.com/W ... n/17473828
and more Manuals
https://support.automation.siemens.com/ ... 2526query=*
