I need to make a basic program on a S7-1200 CPU,
What I need to do is on input 0 I have a switch & I need need to create a sequence for a Project.
When the input is on I need to set output 0 then after ten seconds it will set output 1 then 10 seconds later it will switch off both outputs.....
I would like it if someone could upload a screenshot of what I need using function blocks if possible please.
Thanks Steve
