PLC AB compactlogix L35E y HMI Proface GP2500
deray88
Post by deray88 »
Estimados (sos) :
Necesito configurar una pantalla HMI Proface GP2500, para que las variables de un PLC Allan Bradley Compactlogix L35E puedan ser visualizadas e interactúen con el PLC.
Lo que no puedo hacer es asignar la dirección de memoria en la HMI para que me muestre una variable del PLC.
Investigando supe que hay que hacer un arreglo (array) de memoria para luego direccionarlo en el programa GP-PRO/PB III, pero no lo he podido lograr.
Agradecería que pudieran contarme su experiencia en estos equipos.
(sos)
deray88
Re: PLC AB compactlogix L35E y HMI Proface GP2500
Post by deray88 »
deray88 wrote:Estimados (sos) :
(sos)
Dear ( sos ):
I need to configure a screen HMI Proface GP2500, in order that a PLC's variables Allan Bradley Compactlogix L35E may be visualize and interact with the PLC.
What I cannot make is assigning the address by heart in the HMI in order that a PLC's variable show myself.
Carrying out an investigation I knew that we have to do a repair ( array ) by heart stops next direccionarlo in the program GP PROFIT PB III, but I could have achieved it.
You would thank that they may tell me their experience in these teams.
NowanH
Post by NowanH »
I was thinking about explaining you how to use Map PLC/SLC Messages command in RSLogix but I'm so lazy that I wrote "Application Note #1176: Mapping Native Tags for Access by GP-Pro" in Google. The first item in the list was a pdf document by ProFace explaining what you want to do.
deray88
Post by deray88 »
NowanH wrote:I was thinking about explaining you how to use Map PLC/SLC Messages command in RSLogix but I'm so lazy that I wrote "Application Note #1176: Mapping Native Tags for Access by GP-Pro" in Google. The first item in the list was a pdf document by ProFace explaining what you want to do.
Excellent grade!!!
Problem solved!!! Thank you very much my friend
