how to access eeprom memory program?
Cts349
Hello to all,
I attended a premium PLC TSX 573634M system it has backup EEPROM
memory TSXMFPP001M. I want read this memory program and copy it to
laptop. The problem is once i plug in into my pcmcia slot of laptop, it prompt
"Welcome to found new hardware wizard", seem like it need some software(drivers)
install in my laptop then can read this memory card.
Any ideal?
Thank you.
Any ideal?
Thank you.
vlad2006gr
Re: how to access eeprom memory program?
To work with such a card need a program Memory Card Explorer. Look on the Internet.
Cts349
hello vlad2006gr
My intention is want to retrieve this memory card program and decompile it back to .stu or sta file.
because the user did not have original(master) program and not able to
transfer the PLC to PC although i success connected to PLC. Do not know possible or not.
Now the present processor occasionally giving an Err an IO fault after
trigger the processor back to RUN.
I did a new replacement processor TSX573634M(s.v 3.0) in with this
memory card, once i trigger it to RUN, the processor immediately give Err
and IO fault. (Note : old processor is TSX573634M (s.v 2.
I do not it's because of processor firmware issue or not.
Just for more information, the system have Canopen bus talk to several
ATV drives.
Can you give some advise?
Again thank you.
ATV drives.
Again thank you.
vlad2006gr
Download http://www.4shared.com/rar/jRN69pwXce/M ... _v314.html
You need necessarily an old laptop with pmsia slot. Only Windows XP x32!.
Antivirus installation and operation of the program must be switched off!
When you finish the installation,
ADD those details as they are on Config.sys system file
and SAVE it.....
Then reboot, and run the program.....
IF you taking ERROR, then READ with ATTENTION the MCEHELP file,
and go to Installation Notes and then to "Set-up Strategy" and
make those steps....
Wait, later give further advice.
Good luck!
and SAVE it.....
device=c:\windows\himem.syys and
device=c:\windows\emm386.exe noems x=d000-d3ffIF you taking ERROR, then READ with ATTENTION the MCEHELP file,
Good luck!
Cts349
Hi Vlad2006gr,
I managed install the MCE software but on open this MCE application it prompt error message "Please exit MCE and try other memory window address.
use command line option 'W' to change the memory window from address 300D0000(=W300D0)"
my laptop is running winxp sp3 with 1 slot pcmcia slot.
On MCE icon target box, keying as "C:\ElanPCCard\Memory Card Explorer\MCE.EXE" w300d0
It prompt me error if i key this way "C:\ElanPCCard\Memory Card Explorer\MCE.EXE w300d0"
or C:\ElanPCCard\Memory Card Explorer\MCE.EXE w300d0
Do not know how to proceed further.
I read through the memory card information from catalog, it seem only use for backup application only not with data.
I do not know, after we run through all this process, installing MCE and retrieving the program from memory card.
End up we short of data, then we facing another problem again.
From your experience, what do you think and what is the chances?
Thank you .
Thank you .
vlad2006gr
I asked to wait. Read user manual:
http://www.4shared.com/office/Yqc9eSeZb ... lorer.html
And
http://www.4shared.com/office/2-RPFY_zce/Read_card.html
Send me what you read from the card.
I'll try to help you.
And
Cts349
vlad2006gr
what's this? -
Cts349
The catalog of memory card information.
vlad2006gr
If you want to restore a project, then you need to read the memory card and send it to me. Catalogues I do not need.
Or I do not understand you correctly?
Good luck!
Good luck!
Cts349
Okay, I will come back to you with that Bin file.
Thank you.
Thank you.
Cts349
Attached link for the Bin file.vlad2006gr wrote:If you want to restore a project, then you need to read the memory card and send it to me. Catalogues I do not need.
Good luck!
http://www.4shared.com/file/PVi-RyZ8ce/ ... 34M03.html
Thank you.
Cts349
Cts349 wrote:Attached link for the Bin file.vlad2006gr wrote:If you want to restore a project, then you need to read the memory card and send it to me. Catalogues I do not need.
Good luck!
Thank you.
Vlad2006gr, Any progress?
vlad2006gr
The memory unit consists of 350 units. The need to restore them. It will take time. I need the exact configuration of the controller unit. For Example-
Rack:TSX RKY 12EX
1,2.TSX PSY 5500M
3.TSX P57 3634M 02.30
4.TSX ETY PORT ETHERNET/IP
5.TSX AEY 1614
6.TSX AEY 810
7.TSX AEY 810
8.TSX AEY 810
9.TSX DEY 64D2K
10.TSX DSY 64T2K
11.not
12.not
It will quickly restore the project.
Rack:TSX RKY 12EX
1,2.TSX PSY 5500M
5.TSX AEY 1614
6.TSX AEY 810
7.TSX AEY 810
8.TSX AEY 810
9.TSX DEY 64D2K
10.TSX DSY 64T2K
11.not
12.not
