Hello everyone!
Currently I am using PLC GE FANUC. I have an issue you wish to protect. Currently I am using Proficy Machine Edition version 6.5 software, for programming. In the declaration Ethernet Global Data I can not use the Launch EGD Management Tool; Bind and Build by hiding them down (as attachments). I've reset the machine Proficy edition version 6.5 or higher version, but the situation did not improve. I'm very sure you only need the guidance to overcome, so that the programming of 2 PLC Ethernet Global Data is completed.
Thank you very much !
attach: http://www.mediafire.com/view/zldfsqf5q ... o_Tool.JPG
Please guide how to fix Launch EGD Management Tool
xuanben2
vlad2006gr
Re: Please guide how to fix Launch EGD Management Tool
Have you installed EgdManagementTool Setup?
Is on the way Proficy Machine Edition x.x/EGD Server and Tools/
xuanben2
I have to manually install EgdManagementTool Setup, from Foder "EGD Server and Tools" of Proficy_Machine_Edition_6.5 software. After installation is complete, but no EgdManagementTool Setup is. Add to wish you just told me.
Thank you very much
Thank you very much
vlad2006gr
In your case, it is difficult to help you if you do not see your computer.
Check for correct installation of links:
http://support.ge-ip.com/support/resour ... %20CME.doc
http://www.logic-control.com/datasheets ... -1918P.pdf
