need help moog digipack 100
				akutole
Hi, All. somebody have moog digipack 100 parison controller maintenance and repairing manual? i had problem wiith it, this device can not read analog input, setting proile. Many thanks for your helps.
				Robin Enderby
Re: need help moog digipack 100
You can download the manual here:
http://www.moog.com/literature/ICD/digi ... er-ium.pdf
Is this a new fault, or have you always had the problem?
Read the section about setting the DIP switches.
You will need to recycle the power id you change switch stings.
You can't change some of the settings when the machine is running.
Regards,
Robin Enderby
BMC Controls (UK)
Regards,
Robin Enderby
BMC Controls (UK)
