FactoryTalk View SE Two Monitors
nene
Post by nene »
hi all
Anyone know how to faktorytalk open on two monitors
I have an application with two monitors and I have to manually extend the screen ....
best regards
Nene
NowanH
Re: FactoryTalk View SE Two Monitors
Post by NowanH »
Here 3 different ways:
1. You can run two different instances of the client (one instance running in each monitor).
2. Use x,y coordinates to make appear some displays in monitor #1 and other displays in the monitor #2.
3. Programming wide displays that uses both monitors from the beginning.
